- Joined
- Jul 13, 2016
- Messages
- 9
- Reaction score
- 0
Hi there
I have a strange problem at a customer's place. He's working on a Citrix server which is in our Datacenter, basically "next to" his 3CX Server, which is in a different subnet. In between, there is a firewall, where I have opened the required ports for 3CX:
5060, 5090, 80, 443, 5000, 5001
From my computer at work, the 3CX client can connect to the server. From the Citrix server, it simply won't connect. Here's what the log says about it:
[24.10.2017 09:26:48.143][1] 3CXTunnel: Stopping tunnel service, waiting indefinitely
[24.10.2017 09:26:48.143][1] 3CXTunnel: Tunnel service destroyed
[24.10.2017 09:26:48.143][1] Biz FreeSIPResources finished
[24.10.2017 09:26:48.290][1] LoginCallback() starts
[24.10.2017 09:26:48.291][1] Setting app channel to null, was null
[24.10.2017 09:26:48.291][1] UnsubscribeEventsFromMyPhoneAndCTI()
[24.10.2017 09:26:48.293][1] Setting tmp channel to null, was [ 1789605 at https://SERVERADDRESS:5001/myphone/MPWebService.asmx ]
[24.10.2017 09:26:48.293][1] UnsubscribeEventsFromMyPhoneAndCTI() finished
[24.10.2017 09:26:48.293][1] Error occurred when login to my phone
[24.10.2017 09:26:48.293][1] System.MissingMethodException: Methode nicht gefunden: "Void MyPhoneClientChannelNet.Interfaces.IClientChannel.set_ServerVersion(System.String)".
bei _3CXWin8Phone.MainWindow.SetMyPhoneChannel(LoginInfo login)
bei _3CXWin8Phone.MainWindow.LoginCallback(Object sender, LoginInfoEventArgs args)
[24.10.2017 09:26:48.293][1] LoginCallback() ended
[24.10.2017 09:26:48.293][1] LoginCallback() starts
[24.10.2017 09:26:48.293][1] LoginCallback() channel mismatch: current tmp channel = null, app channel = null, got channel [ 1789605 at https://SERVERADDRESS:5001/myphone/MPWebService.asmx ]
[24.10.2017 09:26:48.294][1] Connection to myphone server [ 1789605 at https://SERVERADDRESS:5001/myphone/MPWebService.asmx ] got established successfully
[24.10.2017 09:26:48.294][1] Closed myphone reconnection message window
[24.10.2017 09:26:48.294][1] Error occurred during myphone connected event
[24.10.2017 09:26:48.294][1] System.Exception: Channel seems to be already disconnected
bei _3CXWin8Phone.MainWindow.channel_Connected(Object sender, EventArgs e)
[24.10.2017 09:26:48.294][1] channel_ServerEvent() channel mismatch: current tmp channel = null, app channel = null, got channel [ 1789605 at https://SERVERADDRESS:5001/myphone/MPWebService.asmx ]
Any ideas? I don't get it.
Regards,
Patrick
Regards,
Patrick
