[Closed] Number of ports in Patton ISDN gateway
Discussion in '3CX Phone System - General' started by paologabrielli, Mar 1, 2016.
  1. paologabrielli
    Mar 1, 2016
    Dear all,
    I would like to ask you if something changed from v12 to v14, because, on v14, when I try to add a new ISDN Gateway (I have a Patton SN4638) 3CX only creates one port (90001), even if in the creation wizard I tell it that I have 4.
    On v12 it created 4 ports (90001, 90002, 90003 and 90004) when I told it that I had 4. And I prefer that way because on the Patton I have 4 different phone number with different purpose.
    But I can't find anything specific in the docs/FAQs, on the Internet, etc.
    Thanks for your time,
    Paolo
  2. paologabrielli
    Mar 1, 2016
    Re: Number of ports in Patton ISDN gateway
    After a big digging,
    I've found, on the third slide from the "Configuring Inbound Routing" presentation of the academy
    http://www.3cx.com/3cxacademy/videos/ba ... d-routing/
    that for the Patton now we have one virtual port per device.
    Thanks all,
    Paolo
  3. paologabrielli
    Mar 1, 2016
    Found in the manual v12.5
    Found in the manual v14
    So, as you can see, it changed from v12.5 to v14.
    Thanks again,
    Paolo
