Solved [Closed] Unable here Operator Messages
Discussion in '3CX Phone System - General' started by Pranav Jairam, May 28, 2017.
  1. Pranav Jairam
    May 28, 2017
    7
    I installed 3CX and it works extremely well. We are using a our old Elastix 2.5 box which has a Digium Card to forward calls to the 3CX as explained the guide. I'm really happy that the documentation is so good. I do have a a small problem though:
    When I dial a mobile number from my 3CX is connects and call clarity is also very good. But if a mobile phone no. is not reachable or busy etc I don't get the operator tone of "The number you are calling is busy/not reachable" , instead I get the 3CX ringing tone even if the mobile no. is off/busy/not reachable etc.
    Could anyone please help?? Its kind of urgent. I checked in google but since I don't know the terminology/keywords for the above I hit a dead end.
    Pranav Jairam
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @Pranav Jairam
    Please navigate to settings / PBX and enable option Play busy Prompt when extension is busy. Let us know if that works for you
  3. Pranav Jairam
    May 28, 2017
    7
    Hi @YiannisH_3CX,
    Thanks for your reply. That didn't help. The issue is only when I dial External Mobile Phone Numbers. If the external mobile phone number is either not reachable/or switched off instead of getting the message sent by the mobile operator I get a ringing tone by 3CX.
    My users think the phone is ringing but the external mobile no. is either busy or not reachable etc.
    Pranav Jairam
  4. YiannisH_3CX
    May 10, 2016
    6,016
    421
    If you get a ringing tone even though the mobile number is busy then possibly the PBX is not receiving a busy message from the provider. Do you get the busy message in the logs? Your best option is running a wireshark capture and see what message comes back from the provider when a mobile number is busy
  5. Pranav Jairam
    May 28, 2017
    7
    Hi @YiannisH_3CX,
    Thanks for your prompt reply. My Elastix 2.5 gets a busy message from the provider. It's only 3CX that doesn't get it from Elastix. PFA my logs of Elastix 2.5 below:
    The mobile phone number was pu ton Airplane Mode while testing. Still got a ringing tone.
    Do let me know how to post 3CX logs and I'll do the same.
  6. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Ive gotten this when going through a patton pri gateway. I had to enable precall announcements (or something like that) .... basically, focus on your digium card, not 3cx ...
  7. Pranav Jairam
    May 28, 2017
    7
    Hi @JaasonNadeau,
    The most surprising thing is that it works on the Elastix 2.5 Dahdi trunk. It just doesn't pass it to the SIP trunk created between Elastix and 3CX. Wondering where the configuration is??
  8. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Its not surprising, different devices act differently together. I haven't used digium cards in years, but I assure you there are settings that go with it. Time to pull out the digium manual ! ;)
  9. Pranav Jairam
    May 28, 2017
    7
    Bump... The entire setup is complete except for this and Outbound Rules for International dialling from India. These two done then I move to the next installation/configuration. ;).
    Can anyone help me with the correct terminology/keywords for the same so I can search in Google??
    #9 Pranav Jairam, May 29, 2017
  10. Pranav Jairam
    May 28, 2017
    7
    Outboud Rules done... only the above thing left... :(
  11. Pranav Jairam
    May 28, 2017
    7
    Ok... Sorted it out a couple of days ago. Sorry forgot to update it. The update for Indian Airtel PRI connection is to enable Fax detection in the Elastix server. Once done its working. Don't know what's it got to do with fax detection but its working.
