cloud 12 CTI ?
Discussion in '3CX Phone System - General' started by egiblockDM, May 12, 2014.
  1. egiblockDM
    Apr 22, 2013
    39
    i can't get the CTI (presense, etc.) to work properly with Cloud v12 and a remote installation of the 3cx system. this was an upgrade from v11 and the myphone application. i couldn't find anything online for a verification that the CTI was working on the server level, or if there is anything to configure for it. My softphone connects fine, but when i switch the modes, i get the attached:
    switching to 3CXPhone mode and the following appears:
    but the softphone will connect to the server and i can made / receive calls.
    switching to CTI mode and i get the following:
    and the softphone doesn't connect at all.
    running 3CX Cloud 12 version 12.0.35110.620
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,565
    302
    are all the required ports open on the server side?
  3. egiblockDM
    Apr 22, 2013
    39
    yes. and after more reading, i don't necessarly need the CTI . i'm just trying to get the presence working in the software..
  4. egiblockDM
    Apr 22, 2013
    39
    once i found the 'send welcome email' i was able to easily set up the softphone for windows, ipad, and android installs with a click of a button.
