Cloud based CRM Integration
Discussion in 'CRM / Helpdesk / App Integration' started by Philip Darnell, Jan 16, 2018.
  1. Philip Darnell
    Philip Darnell New Member
    Jan 26, 2017
    158
    10
    I have a client who uses a cloud based CRM called BrightOffice, which they access using Internet Explorer.
    I want to create some kind of CRM Integration so customer records pop up etc.
    but I don't know where to start, could anyone point me in the right direction to some tutorials?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,602
    126
  3. Philip Darnell
    Jan 26, 2017
    158
    10
    Thanks for the help.
    What is the difference between the two web services SOAP and REST? Is this something I need to find out from the CRMs developers? Or does it not make a difference which I chose?
  4. edossantos
    Jun 27, 2007
    1,602
    126
    Yes, you need to find out from the CRM developers. Those are 2 different approachs to web services. Modern web services are REST based, while old web services use SOAP.
  5. Philip Darnell
    Jan 26, 2017
    158
    10
    I will try speak to the developers today and see how I get on with it.
    If I create the plugin and it doesn't work, how do I diagnose problems?
  6. edossantos
    Jun 27, 2007
    1,602
    126
    3CXPhone logs are located at "%AppData%/3CXPhone for Windows/Logs".
    Kind regards.
    Ernesto.
  7. Mark Geerdes
    Jan 29, 2018
    The Link on that page to download the template generator does not work. Is there another place to download the Generator?
  8. edossantos
    Jun 27, 2007
    1,602
    126
    The link is fixed now, please try again.
