- Joined
- Mar 16, 2011
- Messages
- 1
- Reaction score
- 0
V.9.0.15781.949
I have two Linksys SPA-3102 (most current firmware release) ATAs on the same LAN as the PBX. I'm trying to initiate a call from ATA1 (extension 101) to ATA2 (extension 102). The handset for ATA2 rings. On ATA1 I hear the PBX say, "Cancelled". I have a softphone (extension 103) that can RECEIVE calls from either of the ATAs without a problem. The softphone fails to connect to either of the two ATAs when it initiates the call, receiving the same error as if calling from 101 to 102. The following is the log of the ATA to ATA call. ATA2 is 192.168.5.204 and ATA1 is .203, the PBX is .111. All devices show as registered and Available under Extension Status. Any ideas as to the nature of the CM503003, 400 Bad Request? ... or a reference to an error code document?
14:22:46.157 [CM503008]: Call(26): Call is terminated
14:22:42.757 [CM503007]: Call(26): Device joined: sip:[email protected]:40600;rinstance=a2213c402a853fba
14:22:42.752 [CM503007]: Call(26): Device joined: sip:[email protected]:5060
14:22:42.745 [CM503002]: Call(26): Alerting sip:[email protected]:40600;rinstance=a2213c402a853fba
14:22:42.602 [CM503025]: Call(26): Calling Unknown:Ext.EndCall@[Dev:sip:[email protected]:40600;rinstance=a2213c402a853fba]
14:22:42.547 [CM503016]: Call(26): Attempt to reach <sip:[email protected]> failed. Reason: Not Acceptable HereReason Unknown
14:22:42.542 [CM503003]: Call(26): Call to sip:[email protected] has failed; Cause: 400 Bad Request; from IP:192.168.5.204:5060
14:22:42.466 [CM503025]: Call(26): Calling Ext:Ext.102@[Dev:sip:[email protected]:5060]
14:22:42.428 [CM503004]: Call(26): Route 1: Ext:Ext.102@[Dev:sip:[email protected]:5060]
14:22:42.427 [CM503010]: Making route(s) to <sip:[email protected]>
14:22:42.426 [CM505001]: Ext.101: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:[email protected]:5060]
14:22:42.412 [CM503001]: Call(26): Incoming call from Ext.101 to <sip:[email protected]>
