[CM503013]: Call(C:26): Incoming call rejected, caller
Discussion in '3CX Phone System - General' started by betatester, Jul 3, 2013.
  1. betatester
    Jul 3, 2013
    Hardware and Software
    OS: Windows 8 Professional
    3CX Version: 12
    Phones: Yealink T26, firmware version: 6.70.0.140
    Scenario:
    1. 3CX system behind router at OFFICE
    2. Router has opened/forwarded all necessary ports to static IP of 3CX PBX (192.168.2.20)
    3. Two INTERNAL extensions registered to 3CX PBX
    4. Same two INTERNAL extensions can make and receive INTERNAL calls
    5. One EXTERNAL extension registered to 3CX PBX using STUN
    6. INTERNAL extensions can call EXTERNAL extension
    7. Same EXTERNAL extension cannot make calls to INTERNAL extensions or VoiceMail, ** FORBIDDEN ** on LCD
    Server Activity Log
    02-Jul-2013 22:20:52.914 Got REGISTER for foreign registrar: registrar host <sip:mad:71.72.120.XX:5060> is not mine!
    02-Jul-2013 22:15:26.228 Leg L:29.2[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 76.181.132.XX:5062
    02-Jul-2013 22:15:26.228 [CM503003]: Call(C:29): Call to <sip:9455@71.72.120.XX:5060> has failed; Cause: 487 Request Terminated/INVITE from 76.181.132.XX:5062
    02-Jul-2013 22:15:26.090 [CM503008]: Call(C:29): Call is terminated
    02-Jul-2013 22:15:26.072 Leg L:29.1[Extn] is terminated: Cause: CANCEL from 192.168.2.20:57038
    02-Jul-2013 22:15:24.523 [CM503025]: Call(C:29): Calling T:Extn:9455@[Dev:sip:9455@76.181.132.XX:5062] for L:29.1[Extn]
    02-Jul-2013 22:15:24.290 [CM503027]: Call(C:29): From: Extn:1000 ("PBX-Admin" <sip:1000@192.168.2.20:5060>) to T:Extn:9455@[Dev:sip:9455@76.181.132.XX:5062]
    02-Jul-2013 22:15:24.290 [CM503004]: Call(C:29): Route 1: from L:29.1[Extn] to T:Extn:9455@[Dev:sip:9455@76.181.132.XX:5062]
    02-Jul-2013 22:15:24.281 [CM503001]: Call(C:29): Incoming call from Extn:1000 to <sip:9455@192.168.2.20:5060>
    02-Jul-2013 22:15:19.290 Leg L:28.2[VMail] is terminated: Cause: BYE from PBX
    02-Jul-2013 22:15:19.289 [CM503008]: Call(C:28): Call is terminated
    02-Jul-2013 22:15:19.272 Leg L:28.1[Extn] is terminated: Cause: BYE from 192.168.2.20:57038
    02-Jul-2013 22:15:11.284 Currently active calls - 1: [28]
    02-Jul-2013 22:15:05.369 [CM503007]: Call(C:28): VMail:9999 has joined, contact <sip:9999@127.0.0.1:40600>
    02-Jul-2013 22:15:05.364 [CM503007]: Call(C:28): Extn:1000 has joined, contact <sip:1000@192.168.2.20:57038>
    02-Jul-2013 22:15:05.351 L:28.2[VMail] has joined to L:28.1[Extn]
    02-Jul-2013 22:15:05.207 [CM503025]: Call(C:28): Calling T:VMail:9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=5e672d6ba3bad2b7] for L:28.1[Extn]
    02-Jul-2013 22:15:05.162 [CM503005]: Call(C:28): Forwarding: T:VMail:9999@[Dev:sip:9999@127.0.0.1:40600;rinstance=5e672d6ba3bad2b7]
    02-Jul-2013 22:15:05.162 L:28.1[Extn] forwards call from Extn:5102 to VMail:9999 based on rule Fwd[Available/NotReg]
    02-Jul-2013 22:15:05.161 L:28.1[Extn] failed to reach Extn:5102, reason Not Registered
    02-Jul-2013 22:15:05.115 [CM503017]: Call(C:28): Target is not registered: Extn:5102
    02-Jul-2013 22:15:05.105 [CM503001]: Call(C:28): Incoming call from Extn:1000 to <sip:5102@192.168.2.20:5060>
    02-Jul-2013 22:13:21.984 Got REGISTER for foreign registrar: registrar host <sip:mad:71.72.120.XX:5060> is not mine!
    02-Jul-2013 22:12:30.227 Leg L:27.2[Extn] is terminated: Cause: 487 Request Terminated/INVITE from
    76.181.132.XX:5062
    02-Jul-2013 22:12:30.227 [CM503003]: Call(C:27): Call to <sip:9455@71.72.120.XX:5060> has failed; Cause: 487 Request Terminated/INVITE from 76.181.132.XX:5062
    02-Jul-2013 22:12:29.846 [CM503008]: Call(C:27): Call is terminated
    02-Jul-2013 22:12:29.835 Leg L:27.1[Extn] is terminated: Cause: CANCEL from 192.168.2.20:57038
    02-Jul-2013 22:12:27.194 [CM503025]: Call(C:27): Calling T:Extn:9455@[Dev:sip:9455@76.181.132.XX:5062] for L:27.1[Extn]
    02-Jul-2013 22:12:26.817 [CM503027]: Call(C:27): From: Extn:1000 ("PBX-Admin" <sip:1000@192.168.2.20:5060>) to T:Extn:9455@[Dev:sip:9455@76.181.132.XX:5062]
    02-Jul-2013 22:12:26.817 [CM503004]: Call(C:27): Route 1: from L:27.1[Extn] to T:Extn:9455@[Dev:sip:9455@76.181.132.XX:5062]
    02-Jul-2013 22:12:26.805 [CM503001]: Call(C:27): Incoming call from Extn:1000 to <sip:9455@192.168.2.20:5060>
    02-Jul-2013 22:05:50.979 Got REGISTER for foreign registrar: registrar host <sip:mad:71.72.120.XX:5060> is not mine!
    02-Jul-2013 21:58:19.974 Got REGISTER for foreign registrar: registrar host <sip:mad:71.72.120.XX:5060> is not mine!
    02-Jul-2013 21:54:44.377 Leg L:26.1[Unknown:] is terminated: Cause: BYE from PBX
    02-Jul-2013 21:54:44.328 [CM502001]: Source info: From: "Will Wills"<sip:9455@71.72.120.XX>;tag=1599797407; To: <sip:9999@71.72.120.XX>
    02-Jul-2013 21:54:44.328 [CM503013]: Call(C:26): Incoming call rejected, caller is unknown; msg=Ivite-IN Recv Req INVITE from 76.181.132.XX:5062 tid=30615689 Call-ID=2087174287@192.168.2.2:
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    To sum up -
    Internal extensions work just fine.
    It would be helpful to know which extension numbers are internal or external; just for clarity and ease of read.
    In any event, extension 5102 is not registered; yet appears to be internal. Due to lack of registration, it was forwarded to Vmail.
    Just to confirm, all extensions show to be registered? None of the extension IPs show to be blacklisted?
    The firewall checker passed all tests?
    Is the external extension allowed to be used outside the local LAN? See the other tab for the extension and see if feature/function set correctly.
    When you provisioned the phone, did you do so manually or via the provisioning tab and did you select the correct interface on the tab and regardless of how provisioned, use the settings as stated for an external phone?
