[CM506004]: STUN request to STUN server 75.101.138.128:3478
Discussion in '3CX Phone System - General' started by modsiw, Nov 3, 2008.
  1. modsiw
    Nov 3, 2008
    I'm getting the following error from the latest version of 3cx. I believe it is responsible for my line being unable to register.
    The 3cx machine is behind a NAT. The following ports are forwarded.
    UDP & TCP 10000-50000
    UDP & TCP 9000-9015
    UDP & TCP 5060-5061
    UDP & TCP 3487
    Code:
    10:59:48.045	StunClient::onTestTout	[CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.27.43:5060
    10:59:42.366	StunClient::onTestTout	[CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.27.43:5060
    10:59:38.981	StunClient::onTestTout	[CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.27.43:5060
    10:59:33.303	StunClient::onTestTout	[CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.27.43:5060
    10:59:29.918	StunClient::onInitTests	[CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.27.43:5060
    10:59:24.239 	StunClient::onTestTout 	[CM506004]: STUN request to STUN server 69.0.208.27:3478 has timed out; used Transport: 192.168.27.43:5060
    10:59:19.793 	ListenConnect 	SL: connected ip-pbx:0/PHPExtension_0 at [ip-pbx:0]/PHPExtension_0
    10:59:15.176 	StunClient::onTestTout 	[CM506004]: STUN request to STUN server 69.0.208.27:3478 has timed out; used Transport: 192.168.27.43:5060
    10:59:06.112 	StunClient::onTestTout 	[CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.27.43:5060
    10:58:57.048 	StunClient::onTestTout 	[CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.27.43:5060
    10:58:47.985 	StunClient::onTestTout 	[CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.27.43:5060
    10:58:47.673 	ListenConnect 	SL: connected ip-pbx:0/VoiceBoxManagerService at [ip-pbx:0]/VoiceBoxManagerService
    10:58:43.133 	ExtnCfg::updateContact 	[CM504002]: Ext.*1: a contact is unregistered. Contact(s): []
    10:58:43.133 	ExtnCfg::updateContact 	[CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*1@127.0.0.1:40000;rinstance=b523cc48ac3f1e14/*1]
    10:58:43.118 	ExtnCfg::updateContact 	[CM504002]: Ext.*0: a contact is unregistered. Contact(s): []
    10:58:43.118 	ExtnCfg::updateContact 	[CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*0@127.0.0.1:40000;rinstance=f55c707ffd50f45e/*0]
    10:58:42.743 	ListenConnect 	SL: connected ip-pbx:0/3CXParkOrbit at [ip-pbx:0]/3CXParkOrbit
    10:58:41.094 	ExtnCfg::updateContact 	[CM504002]: Ext.99: a contact is unregistered. Contact(s): []
    10:58:41.094 	ExtnCfg::updateContact 	[CM504001]: Ext.99: new contact is registered. Contact(s): [sip:99@127.0.0.1:40600;rinstance=f362a374e771bc69/99]
    10:58:40.770 	ListenConnect 	SL: connected ip-pbx:5483/IVRServer at [ip-pbx:5483]/IVRServer
    10:58:40.346 	MediaServerConnected 	[CM112000] Media Server is connected
    10:58:40.346 	ListenConnect 	SL: connected ip-pbx:0/MediaServer at [ip-pbx:0]/MediaServer
    10:58:39.031 	CallMgr::onAddIPs 	IP(s) added:[192.168.27.43]
    10:58:38.921 	StunClient::onTestTout 	[CM506004]: STUN request to STUN server 75.101.138.128:3478 has timed out; used Transport: 192.168.27.43:5060
    10:58:32.623 	ListenConnect 	SL: connected ip-pbx:0/3CXConferenceRoom at [ip-pbx:0]/3CXConferenceRoom
    10:58:29.994 	ExtnCfg::updateContact 	[CM504001]: Ext.99: new contact is registered. Contact(s): [sip:99@127.0.0.1:40600;rinstance=f362a374e771bc69/99]
    10:58:29.994 	FaxCfg::updateContact 	[CM504008]: Fax Service: registered as sip:88@192.168.27.43:5060 with contact sip:88@192.168.27.43:5100;user=phone
    10:58:29.994 	ExtnCfg::updateContact 	[CM504001]: Ext.16: new contact is registered. Contact(s): [sip:16@192.168.27.200:5060/16]
    10:58:29.994 	DeviceRecord::DeviceRecord 	[CM305004]: Failed to find a transport to host 192.168.27.200
    10:58:29.994 	ExtnCfg::updateContact 	[CM504001]: Ext.14: new contact is registered. Contact(s): [sip:14@192.168.27.204:5060/14]
    10:58:29.994 	DeviceRecord::DeviceRecord 	[CM305004]: Failed to find a transport to host 192.168.27.204
    10:58:29.994 	ExtnCfg::updateContact 	[CM504001]: Ext.13: new contact is registered. Contact(s): [sip:13@192.168.27.202:5060/13]
    10:58:29.994 	DeviceRecord::DeviceRecord 	[CM305004]: Failed to find a transport to host 192.168.27.202
    10:58:29.994 	ExtnCfg::updateContact 	[CM504001]: Ext.12: new contact is registered. Contact(s): [sip:12@192.168.27.203:5060/12]
    10:58:29.994 	DeviceRecord::DeviceRecord 	[CM305004]: Failed to find a transport to host 192.168.27.203
    10:58:29.994 	ExtnCfg::updateContact 	[CM504001]: Ext.11: new contact is registered. Contact(s): [sip:11@192.168.27.205:5060/11]
    10:58:29.994 	DeviceRecord::DeviceRecord 	[CM305004]: Failed to find a transport to host 192.168.27.205
    10:58:29.994 	ExtnCfg::updateContact 	[CM504001]: Ext.10: new contact is registered. Contact(s): [sip:10@192.168.27.201:5060/10]
    10:58:29.994 	DeviceRecord::DeviceRecord 	[CM305004]: Failed to find a transport to host 192.168.27.201
    10:58:29.994 	ExtnCfg::updateContact 	[CM504001]: Ext.*1: new contact is registered. Contact(s): [sip:*1@127.0.0.1:40000;rinstance=b523cc48ac3f1e14/*1]
    10:58:29.994 	ExtnCfg::updateContact 	[CM504001]: Ext.*0: new contact is registered. Contact(s): [sip:*0@127.0.0.1:40000;rinstance=f55c707ffd50f45e/*0]
    10:58:29.838 	StunClient::onInitTests 	[CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.27.43:5060
    10:58:29.432 	DBA 	[CM501003]: Connected: Database
    10:58:28.933 	CallMgr::findLocalIPs 	[CM501006]: Default Local IP address: [192.168.27.43]
    10:58:28.933 	CallMgr::Initialize 	[CM501002]: Version: 6.1.1787.0
    10:58:28.933 	CallMgr::Initialize 	[CM501001]: Start 3CX PhoneSystem Call Manager
    10:58:28.917 	CallCtrl::thread 	[CM501007]: *** Started Calls Controller thread ***
    10:58:28.917 	LoadLicenceInfo 	[CM501009]: License Info: Loaded Succeeded
  2. craigbrass
    Jul 10, 2008
    7
    I was having the same problem this morning and found changing the STUN servers worked well.
    Go General -> General Settings -> STUN server options and change to the following :-
    stun.ekiga.net
    stun.xten.com
    Leave ports at 3478.
    As soon as I made this change, both my lines registered fine.
  3. sharksfan
    Nov 7, 2008
    7
    Same issue here for the last couple of hours. Changed STUN servers to above and all is well again.
  4. Paulh
    Apr 16, 2008
    27
    I also have the same issue. The 3cx STUN servers are down?
  5. Ricambi America
    Nov 10, 2007
    61
    Same issue here. Solved with Deerfield tech advising different STUN. None of our phones would register.
  6. jparisi
    Oct 1, 2007
    92
    Apparently both stun.3cx.com and stun.xten.com resolve to the same ip.
    Looks like the backup stun server is never even tried.
    I had to use stun.ekiga.net to get things up.
  7. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,887
    189
    The stun server entries resolve to stun.xten.com and stun.ekiga.com
    We will be changing to different stun servers tomorrow. However its best to change the entries to your providers stun server... For example stun.sipgate.net:10000 is a very fast and good stun server
