Codec Pass thru. Is it possible?
Discussion in '3CX Phone System - General' started by rferreirat, Sep 3, 2011.
  1. rferreirat
    Sep 3, 2011
    I recently installed 3XC PBX version 10 and have not been able to place calls using pass thru mode, or either other mode actually, but that is not relevant. I have unchecked PBX delivers audio on both, extension and SIP trunk, and still it does not work, the error message in the log shows "Unsupported Media Type" and Wireshark traces shows the codecs offered in the INVITE message to the SIP trunk are those listed in the Sip trunk config (GSM, g711) instead of those supported by the SPA (g729/g723/g711) , hence the call dies because the Sip trunk does not support GSM or g711. Hope someone can help me or give an idea how to make 3XC to offer codecs according to the caller extension capabilities ?
  2. willow
    willow Member
    Mar 1, 2011
    471
    under the pstn gateway form, you need to set the proper codecs.
  3. rferreirat
    Sep 3, 2011
    I don't have anything configured under "PSTN Devices", only under "Extensions" and "Voip Providers" Call is originated from a extension (SPA-200) and is supposed to terminate on a SIP Voip Provider. Sorry for not clarifying that before.
  4. willow
    willow Member
    Mar 1, 2011
    471
    make sure that to match what your sip provider is supporting. just because the sip trunk in 3cx is set you still need to makw sure that the provider supports it.
  5. rferreirat
    Sep 3, 2011
    Thanks for your reply, the problem I have is basically my SIP provider only accept g729 and g723, and the PBX does not offer those options (at least the trial version) However the SPA200 can handle g729,g723 and g711. That is why I am trying to set pass-thru mode as the endpoints have matching codecs. Do you think that is possible ?
  6. willow
    willow Member
    Mar 1, 2011
    471
    on SIP trunks, most of the time the PBX has to deliver audio as it is the one that is registered and has port 5060 forwarded to it. I do not think that you will be able to get this to work. I would recommend either using the free demo key with 2 SC license or purchase a license. If you need assistance please feel free to contact us if you are in the USA.
  7. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    How to get "Codec Pass thru" is described in http://www.3cx.com/blog/docs/media-server/
  8. rferreirat
    Sep 3, 2011
    It does work, I had to select the option "Supports Re-invite" as well as unset "PBX Deliver Audio" on both the VOIP Provider and Extensions.
    Thanks for your Help.
