Codec Selection
Discussion in 'Windows' started by AldoLinares, Dec 21, 2007.
  1. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    Its possible to select wish codec to use?
    How could i select the codec to use.
  2. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    only incoming call can be set to use which codecs. if you want to select which codec to on client use other soft phone from like X-Lite or other paid phone for G729.....
