codecs
Discussion in '3CX Phone System - General' started by cristina, May 8, 2008.
  1. cristina
    Apr 23, 2008
    12
    Does 3cx support AMR codec?
    How can I chose the codec?
  2. Halea
    Halea New Member
    Jan 5, 2008
    151
    Cristina,
    I think GSM and AMR are the same thing. If you are talking about the wide band AMR, I don't think that 3CX supports it.
    Halea
