Codes supported
Discussion in '3CX Phone System - General' started by Anonymous, Sep 4, 2006.
  1. Anonymous
    Anonymous Guest
    What are the codecs supported?
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Current version supports only G.711 codecs (both a-Law and mu-Law)
