Color of HIGHLIGHTED selections - Version 15
Discussion in 'Ideas' started by kinetix, Sep 22, 2016.
  1. kinetix
    Jan 7, 2010
    24
    We are a Platinum 3CX Partner and have been partners now for almost 8 years...
    I am colorblind. It is near impossible for me to determine which column, row, etc is selected once you click. The highlighted color you selected to use for V15 is near impossible to see for someone that is colorblind - I doubt I am the only person with this problem!!!
    Please make the highlighted selection much more distinct!!!
  2. ccomley
    Apr 6, 2011
    92
    My guess is if you know what you're doing with CSS you can edit this
    C:\ProgramData\3CX\Data\Http\wwwroot\public\app.css
    and tinker with the colour settings. But I've not tried it! I would imagine you can't do any harm if you take a backup of the original file before you have a play with it.
  3. kinetix
    Jan 7, 2010
    24
    Thanks for the comment, however, adjusting that file may be fine for individual installs, but as a Platinum Partner, with all of the various installs, it would be much better to have a setting that could be adjusted that would follow any backup/restore, upgrade, etc.
