Combining telephone line with 3CX
Discussion in 'Ideas' started by kanchana jayathilake, May 29, 2017.
  1. kanchana jayathilake
    May 25, 2017
    11
    Hi Everybody,
    I have installed and configured 3CX Phonce system at my office and its working smoothly with web phones.
    now my superior needs to integrate with local phone system and use.
    now i need to know how can i do that.?
    how can i connect my 3CX system with CO line.
    what needs to install on my server to connect CO line to 3CX?
    Kanchana
  2. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    You need a pstn gateway. Pattons are relatively easy to setup with 3cx.
  3. kanchana jayathilake
    May 25, 2017
    11
    can i directly connect my FXO line with 3CX server?
    which hardware need to install?
  4. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    Yes, with a pstn gateway.
  5. kanchana jayathilake
    May 25, 2017
    11
    is there any document or installation guide?
  6. kanchana jayathilake
    May 25, 2017
    11
    may i know how does it works?im soo beginner to this. thats why these simple questions.
  7. supplenta
    Oct 3, 2012
    35
    The Patton gateway will effectively create a SIP connection between 3CX and the gateway itself where all of the traffic will be passed over.
    If you purchase it from a supplier then they will be able to help you with any issues you have, however there are preconfigured templates within 3CX to allow for easy configuration.
    Here is an example of how easy it is:
    https://www.3cx.com/voip-gateways/patton-smartnode-sn4112/
    Simon
