Combo Call Queue / Ring Group Possible?
Discussion in '3CX Phone System - General' started by BobD, Aug 1, 2011.
  1. BobD
    Apr 25, 2011
    27
    I'm either in the lab or at my desk all day long. I created a Ring Group that contains both extensions as I don't want to have to constantly forward / unforward my calls.
    Now, I'd like to have all my calls Queued so they can wait or transfer to voice mail.
    Any way to do this or is there a better solution?
    Bob
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Hi Bob,
    To be honest a SIP forked setup might be a better solution, 1 extension two phones no queue or ring group needed, also if you want you can have it ring your mobile phone simultaneously.
    Thanks,
    Nate
