Comcast SIP trunk on premise
Discussion in '3CX Phone System - General' started by stever, Oct 25, 2017.
  1. stever
    Sep 25, 2017
    39
    12
    We currently have a traditional PBX with a PRI supplied by Comcast. We are thinking of moving to 3CX on premise with Comcast providing SIP trunks that terminate on premise. The Comcast termination device would have an internal IP. Does anyone have experience with this setup? If not, do you think we would have any problems?
    Pros:
    1. Been happy with our Comcast PRI
    2. Calls won't be traveling on the internet and will have Comcast QOS
    Cons:
    1. Not supported by 3CX
    2. Limits us to on premise installation
    Steve
    10,367
    228
    Comcast supplies (or will supply) a PRI that will then terminate on a (3CX compatible) gateway, or Comcast also supplies the gateway?
  3. stever
    Sep 25, 2017
    39
    12
    We would not longer have a PRI that terminates in house but rather a gateway type device that provides the SIP trunks. Their device (I think Adtran brand) would have an internal IP number that I would point my PBX toward.
  4. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
  5. stever
    Sep 25, 2017
    39
    12
    My understanding was that I didn't need a second NIC card. I thought the process would be to set up a generic SIP provider and point it toward the Comcast gateway.
  6. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    And that gateway is also used for internet?
  7. stever
    Sep 25, 2017
    39
    12
    The "gateway" (I may have the wrong term for that) is only for the SIP trunks. I would put the IP (internal IP on same subnet as PBX server) of the gateway in the Trunk Details of the 3CX SIP trunk setup page.
  8. jvivona
    May 18, 2014
    22
    7
    We just installed for a client with a similar scenario - although it was Charter, not Comcast. Their PBX has an address similar to 10.0.0.10 and the Charter gateway has an address of 10.0.0.11. Just add a generic SIP trunk with that IP as the gateway IP - we put the same address in for the proxy - but it's un-necessary. Charter uses an IP Based deliver - so they needed to know the PBX internal IP in advance - but that's easy.
    We use a number of providers who don't have (or previously had, but no longer) a SIP template. We use the generic template and tweak the parameters as needed.
    The customer with the local net gateway is super happy, call quality is comparable to the PRI.
  9. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    734
    113
  10. stever
    Sep 25, 2017
    39
    12
    That's good news. It sure seems like it is the way to go with on premise if you have concern about call quality or latency. Not sure if the SLA is as good for SIP as it is for PRI, but our PRI has only gone down once in the last two years and that was only for 1.5 hours.
  11. cobaltit
    Mar 22, 2012
    734
    113
    The service delivered should be identical as far as reliability. Effectively all you are changing in the current call path is the PRI gateway getting replaced with the ESG.
  12. phil@lgmanor.com
    Oct 13, 2016
    25
    Comcast will provide (usually) an adtran. Your enterprise manager will give you a form to fill out with the internal IP of your 3CX and what IP you would like the adtran to be (in the same subnet). That adtran IP will become the IP you connect to.
    3CX is fully supported by Comcast. There is a full tested solution with sample setup for 15.x.
    Here is the TekVision certification testing and sample configuration file. (3rd party SIP certification testing company)
  13. stever
    Sep 25, 2017
    39
    12
    Thanks everyone for the good information! Gives me confidence that we are going in the right direction.
