Command Line component now available
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Dec 26, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    We (SWS Development) have created a component to add a drag-and-drop item to your VAD toolbox in the Voice Application Designer that will let you call the command prompt from an IVR and are giving it away for free for already licensed VAD users.
    http://www.utahvoipstore.com/Produc...3cx-vad-call-a-command-line-from-the-ivr.aspx
    Use "Purchase Order" for the payment option and you'll skip having to put in payment details to download it.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    I will try it out, thanks!
  3. comresource
    comresource Member
    May 22, 2009
    303
    Very nice. I would love to test this but I have not been able to justify the cost of the licensed version to the bean counters just for testing purposes. Would be nice if partners could obtain a NFR copy of the VAD for in-house testing.
  4. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    You get a discounted copy from 3CX.
    Plus, the free version still works great and can demonstrate how it works overall very well. Have you downloaded the free version?
  5. comresource
    comresource Member
    May 22, 2009
    303
    I played with the old version for a bit but have not downloaded the V8 version.
