Command line
Discussion in 'Windows' started by kasper76, Aug 21, 2010.
  1. kasper76
    Aug 21, 2010
    I would lie to make calls and hang up from within our flash crm.
    Is there a list of command line actions available?
  2. Discovery Technology
    Apr 19, 2008
    278
    Hi Kasper,
    Try taking a look at the following link:
    http://www.3cx.com/blog/docs/command-line-api/
    There are some other useful tips in this part of the 3CX website as well that you may want to take a look at.
    Make sure you have your TAPI drivers working as well...
    Cheers, Brendan
