Command Line
Discussion in '3CX Phone System - General' started by andk, Apr 9, 2014.
  1. andk
    Jul 16, 2013
    6
    Do you know if it is possible to make a call from the Windows Command Line ?
    Thanks in advance!
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,281
    246
    If you have pro version - yes - using "CallTriggerCmd.exe" found in "C:\ProgramData\3CXPhone for Windows\PhoneApp" as part of the "3cx Phone for Windows" package.
    You can do HTTP Dialing as well with some phones.
