Company Directory Sync Not working
Discussion in '3CX Phone System - General' started by mrteriyaki, Mar 21, 2016.
  1. mrteriyaki
    Mar 16, 2016
    I'm having trouble connecting the Company Phonebook to our MSSQL database.
    I have a Pro Server License (Without maintenance contract)
    The testing tool shows the correct data using settings:
    Connection string: DSN=GICI;UID=GICI; PWD=testpassword!@#
    Query: select companyname,phonenumber from view3CX where phonenumber like '%%number%'
    Assignment: firstname=0,phonenumber=1,company=0
    However when using the same settings with 3CX I get nothing, I can't find any error messages, nothing on the ODBC trace log.
    The server is running V14 SP3.
    I've also tried the preference over LDAP option both disabled and enabled.
    Can anyone advise what I'm doing wrong?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Ensure that your DSN string has been input in 3CX without "DSN=" as this will be prepended automatically by the system.
    Also, make sure that the fields have been mapped starting from 0, for e.g Company: 0, Mobile: 1.
    Finally, note that a query for matching will be sent only when a call from an unknown number is answered.
