Company Phone book
Discussion in '3CX Phone System - General' started by jasonhayes, Jul 6, 2015.
  1. jasonhayes
    jasonhayes New Member
    May 9, 2012
    140
    9
    Is it by design that when on a call (handset or 3cx Softphone), that the 3CX Company Phone book no longer lets you lookup a phone number via the Softphone. You can see the entry in the phone book, but not the number. It used to show, it was usefull if someone was on the phone and you need to tell them another contacts telephone number. The two screen shots attched show when you are not on the phone and you can see the contacts number and when on the phone it doesn't show. Can anyone help?
  2. charles
    Apr 27, 2015
    29
    Hi Jason, In both cases your phone book entries should show all the details. I could not reproduce the issues. Try to add a personal contact into your phone book and test it, then let me know.
  3. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Hi there,
    Can you verify that you see presence ? Furthermore also let us know how did you provision the 3CX Phone for Windows
    Regards
  4. jasonhayes
    May 9, 2012
    140
    9
    Yes, from the "Presence Information" screen, where the actice calls, Queue Calls info is display, you can see the details including phone number when both on and off the phone.
