Company Phonebook edit/delete
Discussion in '3CX Phone System - General' started by SaraDDPS, May 26, 2015.
  1. SaraDDPS
    May 26, 2015
    Hello all,
    I use 3CX and was wondering if there was a way for someone to edit/delete contacts from the company wide phone book? We have a few people that are no longer with our company and I would like to delete their contacts. Thank you!
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    Log in to the 3CX Management console, go to Settings > Company Phonebook and edit/delete/change your contacts.
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    End users call also delete phone book entries, if they have the correct permissions within 'Extension Group'.
