Solved Company Phonebook
Discussion in 'iOS' started by complex1, Dec 15, 2016.
  1. complex1
    complex1 Active Member
    Jan 25, 2010
    832
    52
    A simple question from one of my customers which I can't answer:
    Is it possible to block the company phonebook for some users who are using the 3CX client?
    There is no need to see who is in the company phonebook, only the phonebook that resides on their device is important.
    Is here a solution or workaround for?
    Thank you.
  2. complex1
    Jan 25, 2010
    832
    52
    The customer has found a solution and fixed it…
    Instead of the use of the 3CX client, he is now using a different softphone.
    Issue solved.
