Compare xml file and return variable
Discussion in 'Call Flow Designer' started by fidoka, Mar 19, 2018.
  1. fidoka
    Mar 17, 2016
    Hello everyone,
    I'm new with CFD and with C# too.
    My goal is to take a PIN from the user, read a xml file and compare the inserted PIN to the file and return the "Extension".
    This is the xml file:
    <customerPIN>
    <customer PIN="8578" Extension="871"/>
    <customer PIN="8583" Extension="872"/>
    <customer PIN="8669" Extension="857"/>
    <customer PIN="9087" Extension="859"/>
    </customerPIN>
    Can you help me with the C# script i need to use?
    Thank you very much
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,609
    126
    Hello @fidoka,
    Please take a look at this guide:
    https://www.3cx.com/docs/cfd-creating-phone-support-portal-3/
    It shows how to validate the ID and PIN entered by the caller. In your case, you just need to validate the PIN, and then return the Extension. You need to make minimal changes to the script provided in the sample.
    Kind regards.
