Compatibility Windows Terminal Server
Discussion in 'Windows' started by Makoez, Apr 22, 2014.
  1. Makoez
    Apr 3, 2013
    Good afternoon,
    Is there any way to use the 3CX Phone for Windows client on a Windows 2008 Terminal Server?
    We are using 3CX Version 12 (32127.322)
    When i install the client on the server and the extensions connect, i only see 1 extension registered.
    Is there a workaround for terminal servers?
    10,855
    301
    If your operating system isn't listed on this site, yet it installs, you may have some problems.
    http://www.3cx.com/docs/installing-3cx/
    That is not to say that the problems you are having are OS related, it may be something else. Provide a bit more information about the extensions. Check the 3Cx server log for clues as to what is happening. the fact that one extension did register is a good sign.
    If there were a critical issue,with that OS version, then I would expect that the install would have aborted.
    If there is actually a compatibility issue, then I would also suspect that there will not be a "work around".
