compatibility with “answer/end” of the GN Netcom / Jabra
Discussion in 'Windows' started by alphachrome, Apr 28, 2008.
  1. alphachrome
    Aug 29, 2007
    7
    It is possible to make the 3CX Client compatible with the “answer/end” of the office headset of Jabra (ex GN9330) ?
    Merci Jacky
  2. Datorfixarna2
    Dec 12, 2009
    We would really like to have an answer on this. It should be really reasy for 3CX developement to implement this!
    We are using the great "Jabra GO 6430" with up to 100m range.
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,442
    61
    You asked exactly the same question just few days ago, and I answered then:
    http://www.3cx.com/forums/no-funct-answer-key-on-jabra-headset-with-3cx-softphone-12805.html#p69569
  4. tommyjon
    Sep 19, 2011
    You need to figure out a way for the virtual PBX to add the hookswitch capabilities. When the Call / Answer button is activated to the base of the GN Netcom 9330e or 9350e, it sends a hook switch signal to answer the call.
