Compatibility
Discussion in '3CX Phone System - General' started by jits04, May 18, 2007.
  1. jits04
    May 2, 2007
    76
    Is 3cx phone system compatible with ISDN PCI Card (with CAPI 2.0)?
    If yes, have you already tested one?
    thanks again
    William
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,913
    220
    No, it only works with cards or gateways that have a SIP interface. You can find the supported list of gateways here
    http://www.3cx.com/support/voip-gateways.html
  3. jcka
    Sep 19, 2007
    BRI ISDN cards
    Why don't you write a interface for Capi? (In Europe) many small companies using 1 or 2 ISDN lines. A BRI ISDN card is a low cost possibility to migrate to a Voip PBX.
    Use ISDN cards with the HFC chipset, used by many brands (same Capi).
    At this moment we are testing the SipCat server (asterisk based) which has a standard detection voor these cards.
  4. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    Looking around I see SIP ISDN gateways that would work with 3CX. 3CX does not support internal cards and there are SIP external gateways to talk to just about anything using SIP standard. I think it makes sense from a business standpoint not to have to write drivers (and support them) for hundreds of different boards on the market.
  5. Nick Galea
    Jun 6, 2006
    1,913
    220
    VOIP gateways
    VOIP gateways will perform much better and are much more scaleable. Patton is launching a 2 port BRI ISDN gateway, the 4554, that will have an enduser price of about 350 euros.
    Very inexpensive, and a much better solution then using some outdated ISDN card. Remember the old ISDN cards wont even have echo cancellation.
    Its time to invest in the better and newer technology rather then hold on to the old stuff.
