Compatible Analog Phones
Discussion in '3CX Phone System - General' started by Sqwidd, Feb 10, 2010.
  1. Sqwidd
    Feb 10, 2010
    What would be a good model or models of an analog phone(s) that is compatable with the 3cx system? Any recommendations?
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Pretty much any analog phone will work so long as you have an FXS port available via an ATA, SIP Gateway, or Sangoma A200 card.
  3. Sqwidd
    Feb 10, 2010
    Good deal. Any particular analog phones you could recommend? Not recommend? I think for the most part we will use Voip or SIP but in some cases analog will be used for cost purposes and not having to rewire.
    Thanks again
    Jason
  4. KerryG
    Jun 19, 2009
    960
    There are probably a bajillion analog phones out there, if it works when plugged into a phone line, it will work when plugged into an FXS port.
  5. leejor
    10,834
    294
    Almost all except a rotary dial phone
