Compressed WAN calls
Discussion in '3CX Phone System - General' started by Pauliebrisbane, Nov 14, 2014.
  1. Pauliebrisbane
    Nov 14, 2014
    17
    I am new to 3cx and I can't find any info on forcing compression or uncompressed voice depending on IP address or location.
    e.g. a single 3cx server at the main site and a secondary site with users connected the 3cx server over a WAN link.
    When the users call each other internally at the same site it prioritises G.711, but if you are calling over the WAN the first choice is G.729.
    Is this function possible?
    Cheers
    PB
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,333
    256
    Could you perhaps change the available codecs on the handset?
  3. leejor
    10,781
    287
    You can specify the Codecs to be used (usually preferred order) in both the handsets and on trunks groups. The first common denominator will then be used. Off hand I can't remember if that options is available on Bridge Trunks, which is what I assume you are using.
    If you are using VPN to the remote location, then, as Craig suggests, the Codec selection in the set will be the only options available and as a result it may come into "play" for more than just calls over the WAN.
    You do realize that the G729 Codec is a licensed product.
  4. Pauliebrisbane
    Nov 14, 2014
    17
    I understand that G.729 is licensed. Though I would of expected the ability to automatically select G.711 or G.729, iLBC etc depending on the logical location or grouping.
