Concatenate function and "<"
Discussion in 'CRM / Helpdesk / App Integration' started by ip19, Jan 3, 2012.
  1. ip19
    Feb 7, 2011
    15
    hi,
    I'm trying to send an HTML formatted email with VAD, but ther's a problem with concatenate function.. if you try
    CONCATENATE('<','TEST')
    It will always give error BADFETCH
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Mmmm, I think this is because the script is into a XML block. Maybe we need to automatically escape it.
    Meanwhile, try to use this expression:
    CONCATENATE('&lt;','TEST')
    &lt; is the escape sequence for the less than sign in XML. Please, give it a try and let me know.
    PS: Also, if you need > you should use &gt;
  3. ip19
    Feb 7, 2011
    15
    I will try and give you a feed back
    No, the > sign is correctly interpreted :)
  4. VAD_Support
    Aug 6, 2009
    690
    Weird. OK, let me know.
    Thanks,
