Concatenate
Discussion in 'CRM / Helpdesk / App Integration' started by shainjetly, Apr 14, 2010.
  1. shainjetly
    Apr 11, 2010
    9
    can anyone explain how can i use CONCATENATE function.
    i want retrieve a string a from the database and want to concatenate it. how do i retrieve the concatenated results from it??
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    The CONCATENATE function returns a string containing the concatenated result. You need to assign it to some other variable. You need to use a Variable Assignment component, and then use the CONCATENATE function in the Expression field.
  3. shainjetly
    Apr 11, 2010
    9
    Thankyou very much vad support.
    i have developed the application i wanted.
    basically the application will check a user-input number against a database and playback the user-input number to the customer telling whether the number is registered in the system or not. VAD is great.
  4. VAD_Support
    Aug 6, 2009
    690
    Thanks for your feedback!
