Concurrent Calls ( On Same Account ) not Ringing
Discussion in '3CX Phone System - General' started by alex22alex, Aug 7, 2008.
  1. alex22alex
    Jun 11, 2008
    38
    I have a sip account that supports concurrent calls. I set it up as a trunk and i can make two calls out at a time no problem. However when one person calls in the phone rings and you can answer fine. However when i second person calls ( at the same time ) neither of the phone rings or register a call. However the person gets a ringing noise despite the fact the phones are not ringing !!
    Can any one shed any light on this for me ? I can post logs or whatever if needs be.
    Thanks in Advance Alex
  2. alex22alex
    Jun 11, 2008
    38
    Just to elaborate. I have a ring group setup for two handset to test this setup so thats not where the problem lies.
    Alex
  3. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hi Alex
    I think it will be in VoIP Provider Account Details - Maximum simultaneous calls
  4. alex22alex
    Jun 11, 2008
    38
    I checked and its at 10 currently :( Still not luck.
    Nothing seems to get posted on the log when second person calls in ?
    Alex
  5. alex22alex
    Jun 11, 2008
    38
    Just chasing this up does anyone else have a problem with 3CX additional additional calls on some networks.
    My voip provider (http://www.voipfone.co.uk) say they have tested it and encountered the same problem ?
    Thanks Alex
  6. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    Try to use the VOIPOn template when setting up this VOIP provider under LINES->Add VOIP.
    Confirm that in the 3CX configuration under Line(s) Configuration -> Other Options you set the Maximum simultaneous calls to 10.
    When then receiving the second and further calls, does the Server Status log show that the call is coming in? if it does not appear then it means the call is not arriving to 3CX.
  7. alex22alex
    Jun 11, 2008
    38
    Thanks for the message i shall try this and post back to the forum.
    Regards Alex
  8. alex22alex
    Jun 11, 2008
    38
    Right i tried this and it made no difference. The second call never rings any of the handsets in the group. Nothing appears on the "Server Status" section of the admin panel when the second call is supposed to be coming through. My voip provider VoipFone say that 3CX is not answering the requests for the second call. Any ideas as to why this would be ? or what could be happening ?
  9. alex22alex
    Jun 11, 2008
    38
    Any idea's anyone ? Thanks in Advance Alex
