- Joined
- Mar 25, 2009
- Messages
- 12
- Reaction score
- 0
Trying to build a VAD App to do the below
Caller calls in and then is asked to enter a password, if the correct password is entered then the caller is transferred, if the password is incorrect, it will ask the caller to enter the password again.
am at at the conditional component
If i use a conditional VAD Expression such as equal and enter the desired password it builds ok and gets applied to 3cx, however when testing it out it does not take note of the password and just transfers the call anyway.
What am i doing wrong?
