Conerence room take 100% cpu
Discussion in '3CX Phone System - General' started by sharmack, Nov 28, 2008.
  1. sharmack
    Oct 7, 2008
    20
    Has any one got a problem with Conference Room taking 100% of CPU resources?
    I use version 7.03 Small Business
    Everytime Conference room starts it makes CPU run 100%
    as soon as I stop this services CPU goes down to 1-2%
    Anone knows how to configure it to stop taking CPU time for itself?
    Cheers
    Shaun
  2. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    We will need the following pieces of information:
    netstat -ano > NAMEOFFILE.txt - to generate the output in a text file and send it to me by email. nb@3cx.com
    Also I will need the backup of your configuration.
    The conference server when IDLE should not take more than 10MB of memory - 00 % CPU usage. Even under load - with a group of 4 persons in a conference CPU usage remains 0 - 1% and memory increases to 13 MB. These are values taken on a 64 bit Vista machine but they should not differ much across platforms.
    Can you try and restart the configuration service? This is not available in the services page - you have to go and restart it from windows. This will restart all the Dependant services Including conference.
  3. sharmack
    Oct 7, 2008
    20
    I have sent you all files requested
    I have tried to stop/start ir , reboot windows etc but it doesnt help
    Every time CR starts it takes 100% CPU as soon as I stop the service
    CPU drops to 1-5%
    Cheers
    Shaun
