Solved Conference Add Participants Import
Discussion in '3CX Phone System - General' started by jasonhayes, Mar 10, 2018.
  1. jasonhayes
    jasonhayes New Member
    May 9, 2012
    140
    10
    Anyone know the format for using the Import function the files needs to be in, I have tired everything. CSV (guessing), but what what format within the file.
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
    Hello @jasonhayes
    When using the Import Function you can only import Email addresses. So just insert an email address per line, save your file to .csv and import.
  3. jasonhayes
    May 9, 2012
    140
    10
    Thank you.
  4. mariosM_3CX
    Nov 1, 2017
    406
    40
    No problem, glad to help
