Conference and FAX services using 127.0.0.1
Discussion in '3CX Phone System - General' started by garrycarpenter, Jun 11, 2008.
  1. garrycarpenter
    Nov 28, 2007
    20
    Just upgraded ro V6 RC1 and am having problems with the Conference and FAX services.
    If I dial the conference number, it rings, answers, but I can not hear anything. Same with the FAX service.
    Looking through the logs I can see that the server is using 127.0.0.1 for the local address:
    14:28:29.144 Call::Terminate [CM503008]: Call(88): Call is terminated
    14:28:29.050 Call::Terminate [CM503008]: Call(88): Call is terminated
    14:28:20.127 CallLeg::eek:nConfirmed Session 2114 of leg C:88.1 is confirmed
    14:28:20.002 CallCtrl::eek:nLegConnected [CM503007]: Call(88): Device joined: sip:7777@127.0.0.1:40300;rinstance=4335225c3b38d349
    14:28:19.986 CallCtrl::eek:nLegConnected [CM503007]: Call(88): Device joined: sip:7020@10.0.3.20:5060
    14:28:19.986 MediaServerReporting::SetRemoteParty [MS210003] C:88.1:Answer provided. Connection(transcoding mode):10.0.3.1:7366(7367)
    14:28:19.986 MediaServerReporting::SetRemoteParty [MS210001] C:88.2:Answer received. RTP connection: 127.0.0.1:40336(40337)
    14:28:19.986 CallLeg::setRemoteSdp Remote SDP is set for legC:88.2
    14:28:19.986 Extension::printEndpointInfo [CM505001]: Ext.7777: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Conference Place] Transport: [sip:127.0.0.1:5060]
    14:28:19.986 CallCtrl::eek:nAnsweredCall [CM503002]: Call(88): Alerting sip:7777@127.0.0.1:40300;rinstance=4335225c3b38d349
    14:28:19.470 MediaServerReporting::SetRemoteParty [MS210002] C:88.2:Offer provided. Connection(transcoding mode): 127.0.0.1:7368(7369)
    14:28:19.438 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(88): Calling: Ext:Ext.7777@[Dev:sip:7777@127.0.0.1:40300;rinstance=4335225c3b38d349]
    14:28:19.438 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:7777@10.0.3.1]
    14:28:19.438 MediaServerReporting::SetRemoteParty [MS210000] C:88.1:Offer received. RTP connection: 10.0.3.20:16390(16391)
    14:28:19.376 CallLeg::setRemoteSdp Remote SDP is set for legC:88.1
    14:28:19.376 Extension::printEndpointInfo [CM505001]: Ext.7020: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA941-5.1.8] Transport: [sip:10.0.3.1:5060]
    14:28:19.344 CallCtrl::eek:nIncomingCall [CM503001]: Call(88): Incoming call from Ext.7020 to [sip:7777@10.0.3.1]
    3CX server is 10.0.3.1
    Linksys SPA941Phone is 10.0.3.20
    Anyone got any ideas?
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Try to change codec's priority at your phone. Make sure that G729 is NOT on top.
  3. garrycarpenter
    Nov 28, 2007
    20
    Thanks Archie but it has made no differance....
    I dial 7777 (conference) it rings, answers and then nothing....The line stays open but I can hear nothing.
    I have also found that if I call voicemail when I do not have any mail waiting, after entering my pin and pressing # I get nothing as well. If I have a voicemail however, all works fine...
  4. garrycarpenter
    Nov 28, 2007
    20
    Sorted the conference issue..... I did a fresh install and recovered the config from a backup.
    Out recovered custom voice prompts does not list the new conferance prompts and so the system had nothing to play.
    I have now changed to the standard English prompts and conferance now works....small undocumented feature.....lol
    Still have the voicemail issue though - not a big one but does stop people changing their voicemail config via their phone without first leaving themselves a message....
