Conference and Simultaneous Calls
Discussion in '3CX Phone System - General' started by lcircle, Dec 19, 2017.
  1. lcircle
    Dec 12, 2017
    9
    I see on the our license that we are allowed 10 meeting participants, and 4 simultaneous calls.
    During a audio conference today (with 4 participants on one sip trunk), we were notified that we had reached our sim call limit of 4 and all other calls are rejected.
    Is this the normal behavior under the terms of the license?
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    yes, it is normal -- you are allowed to have 4 simultaneous calls (sip) and 10 participants in webmeeting (webrtc), these are different technologies, sip is used for normal audio calls (via sip trunk providers) or between extensions (ip phones), while webrtc is used in webmeetings over internet, hosted on a server, managed by 3CX.
  3. lcircle
    Dec 12, 2017
    9
    Is there a way to increase the 4 sim license to 8 sim calls?
  4. pact
    pact New Member
    Dec 16, 2009
    219
    41
    Yes, Purchase an upgrade to your 3CX License :)
    viraltechnology likes this.
  5. viraltechnology
    Mar 22, 2015
    39
    6
    Speaking of this, whats everyones ruld of thumb for licesing when quoting out a new system? one to one? try to guessbased upon call volume? we just sold a 4sc to a small office of 6. they actually hit the limit the other day.
  6. lcircle
    Dec 12, 2017
    9
    the marketing literature says 1 sim call per 4 extensions. Not so much.
  7. pact
    pact New Member
    Dec 16, 2009
    219
    41
    It is a case-by-case basis.
    A call center will require a higher contention ratio than an auto mechanic.
  8. sip.bg
    Nov 7, 2016
    704
    220
    There is a math theory on the topic, it is not marketing.
    The PBX load is measured in Erlang C. For a normal office (with load 0.1 - 0.2 Erlangs) you need typically:
    4 SC for 8 -10 extensions
    8 SC for 24 - 30 extensions
    16 SC for 64 - 80 extensions
    32 SC for 160 - 200 extensions
    and so on. Search internet for Erlang C.
