Conference audio quality
Discussion in '3CX Phone System - General' started by Bronston Hansen, Dec 6, 2018 at 6:35 PM.
  1. Bronston Hansen
    Jul 24, 2018
    25
    I needed to have a brief meeting a couple days ago with 2 other people. All three of us called into my 3CX conference DID from external numbers (nothing connected to 3CX). The audio quality for all of us was terrible. Everything sounded muffled and was only intelligible when we all spoke very loudly and clearly.
    Digging around in 3CX I don't see any codec settings or adjustments I can make to fix this.
    Can anyone point me in the right direction or has anyone had this issue and resolved it?
    Thanks,
    Bronston
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,557
    234
    That just sounds like a regular audio conference which is going to use the dialtone/internet/codecs used for a regular call.
  3. Andyshawn
    May 1, 2018
    33
    6
    So here is my feedback on the issue you are reporting.
    You created a DID and pointed it to the 3CX server and all three participants dialed in directly via the PSTN, which means you call was using the GSM codec, so you won't get that crystal clear audio quality. However, the call quality show not be that poor, so my guess is that it was just a one time issue poor connection or a very low quality codec was negotiated.
  4. Bronston Hansen
    Jul 24, 2018
    25
    Thanks for the reply.
    Unfortunately it wasn't quite one time. This was the first time I tried to use the conference number so prior to the call I mentioned I tested it with another person. We had the same terrible quality so I opt'd not to use it. Later for the meeting the alternative we were going to use failed to work entirely so we ended up using the conference number anyway.
    Is there anyway to adjust the codec it chooses? I guess I can probably change it on the trunk but I believe that would mean creating a separate isolated trunk just for this DID. Doable but not ideal. Unfortunately at the trunk provider level the codecs and priority are global so there's no way to force it there that I'm aware of.
  5. cobaltit
    Mar 22, 2012
    1,557
    234
    What I was getting at is that the conference all isn't treated any different than a regular call so all calls will sound like garbage if its a provider or network issue. I don't believe it to be a codec issue.
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,530
    298
    Or not... could all be pure VoIP...
  7. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,301
    530
    Hello @Bronston Hansen
    What happens when you call into the system and an extension picks up? Is the quality then the same? What happens if you join a conference call with 3 extensions? Is the quality then the same?
