Conference call outside phone number
Discussion in '3CX Phone System - General' started by BrentNL, Aug 11, 2017.
  1. BrentNL
    Jun 22, 2017
    I must be missing something, but after a lot of time researching I can't find the answer. How do you get outside callers to connect to the conference line? My generated emails have the conference ID number, but not an outside dial in number, such as (555) 555-1212. See below:
    You are invited to attend the following conference call: Test
    To participate, please dial and enter this Conference ID ###387 to join the conference call at the specified time.
    Internal employees can join the conference by dialing 7000 and entering conference ID ###387 when prompted.
    Conference description: This is a test audio conference.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,250
    202
    You have not mentioned which version
    In 15.5, settings - conferencing - audio. Type in the external number routed to extension 700 (default)
