Conference Call & Phantom Extension
Discussion in '3CX Phone System - General' started by CSoft, Oct 6, 2008.
  1. CSoft
    Dec 4, 2007
    9
    Hi ,
    I’m experiencing the following problems :
    1 - Conference call
    I’m trying to make conference call with no result at all.
    When I call the extension 700 , I get connected, but no audio response comes from the system.
    Before knowing that 700 was the default conferencing extension I had configured the 700 extension to a user
    That I later moved to another extension.
    Here you can find detailed log entries of confernce call ..
    13:02:44.000 Extension::printEndpointInfo [CM505001]: Ext.700: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Conference Place] Transport: [sip:127.0.0.1:5060]
    13:02:44.000 CallCtrl::eek:nAnsweredCall [CM503002]: Call(1): Alerting sip:700@127.0.0.1:40300;rinstance=b37123023e1cb82c
    13:02:43.546 MediaServerReporting::SetRemoteParty [MS210004] C:1.2:Offer provided. Connection(proxy mode): 127.0.0.1:7030(7031)
    13:02:43.515 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(1): Calling: Ext:Ext.700@[Dev:sip:700@127.0.0.1:40300;rinstance=b37123023e1cb82c]
    2 – Phantom Extension
    To solve the previous problem I set the log detail to full, and I found that on startup the server try to register
    Many extensions that I don’t actually have in my extension list (737,738,739,740 ,809 ??) .
    Here following there is a sample of the log .
    13:00:41.812 ExtnCfg::updateContact [CM504001]: Ext.740: new contact is registered. Contact(s): [sip:740@127.0.0.1:40300;rinstance=6201371b753c6812/740]
    13:00:40.937 ExtnCfg::updateContact [CM504001]: Ext.739: new contact is registered. Contact(s): [sip:739@127.0.0.1:40300;rinstance=4001e56b53213b40/739]
    13:00:40.390 ExtnCfg::updateContact [CM504001]: Ext.738: new contact is registered. Contact(s): [sip:738@127.0.0.1:40300;rinstance=5e70f17ade043c1e/738]
    13:00:39.937 ExtnCfg::updateContact [CM504001]: Ext.737: new contact is registered. Contact(s): [sip:737@127.0.0.1:40300;rinstance=7701dd2b48767504/737]
    13:00:39.500 ExtnCfg::updateContact [CM504001]: Ext.700: new contact is registered. Contact(s): [sip:700@127.0.0.1:40300;rinstance=b37123023e1cb82c/700]
    13:00:37.546 ExtnCfg::updateContact [CM504001]: Ext.809: new contact is registered. Contact(s): [sip:809@127.0.0.1:40600;rinstance=f606e932a638ac65/809]
    13:00:37.000 ExtnCfg::updateContact [CM504001]: Ext.805: new contact is registered. Contact(s): [sip:805@127.0.0.1:40600;rinstance=6b10f14d573fd04c/805]
    13:00:36.437 ExtnCfg::updateContact [CM504001]: Ext.802: new contact is registered. Contact(s): [sip:802@127.0.0.1:40600;rinstance=fd3cec43c344a72b/802]
    My 3CX version is 6.0.806.0 running on windows server 2003.
    Can you help me ? Any suggestion would be appreciated.
    Thank you
    R.Fabbri
    Roberto Fabbri
    C.Soft S.r.l.
  2. avacchet
    Oct 2, 2008
    Hi, have you set up italian as default language?
    go in system message and set english as default language. i think it's work now.
    let me know, i've solved
