Conference emails via 3CX not sent
Discussion in '3CX Phone System - General' started by Flash99, Oct 29, 2018.
  1. Flash99
    Aug 3, 2017
    98
    8
    I think that since the last update 3CX is not sending emails after creating conferences
    Test email from 3CX works fine
    We are using our own email server
    Any idea why ?
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,590
    238
    So if it's your own email server then you should be able to troubleshoot. What to the logs on your email server say? There appears to be an issue with Office 365 and conference emails but 3CX SMTP works fine.
  3. Flash99
    Aug 3, 2017
    98
    8
    We are using Office 365
    Whats the issue ?
  4. cobaltit
    Mar 22, 2012
    1,590
    238
    If you are using Office 365 why did you say your own? Anyways, you already know what the issue is, it's in the subject of your post. 3CX has not admitted there is an issue but there are multiple threads about conferences emails not sending and Office 365. Using 3CX SMTP works as does using other options besides O365.
  5. Flash99
    Aug 3, 2017
    98
    8
    By my own I meant not 3CX SMTP
    I don't see anything in the message traces
    Voicemails and tests emails are there, but not the conferences
  6. cobaltit
    Mar 22, 2012
    1,590
    238
    Good luck! I strictly use 3CX SMTP on all my installs so it's one less moving part. There will definitely be people interested if you find a resolution or at least identify the cause.
  7. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,554
    300
    #7 craigreilly, Oct 29, 2018
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    Please note that we are investigating an issue with Office 365 accounts and conference emails. We will let you once we have something further.
  9. trams
    Jul 28, 2015
    Hi, any news on fixing the mobile app conference emails, using Office365 ?
  10. YiannisH_3CX
    May 10, 2016
    7,358
    535
    Unfortunately our development team is still looking into this issue. If possible i would recommend using the 3CX SMTP for now.
  11. ProudCanadian
    Aug 24, 2017
    47
    6
    Sorry to drag up an old thread, but really hoping for an update on this as I have had a number of users complain about the issue. I unfortunately cannot use the 3CX SMTP service due to our networking config.
  12. cobaltit
    Mar 22, 2012
    1,590
    238
    Nope. What about your networking config is stopping you from using 3CX SMTP? If your network is locked down so tight you clearly had to make adjustments to hit Office 365 so you should be able to do the same for 3CX SMTP.
  13. ProudCanadian
    Aug 24, 2017
    47
    6
    As far as I am aware the connection has to come from the same IP as your public static IP. Unfortunately that is not the case with us as we have a small range of external addresses.
  14. cobaltit
    Mar 22, 2012
    1,590
    238
    Yes you are correct.
    So you don't have an rule NATing your outbound traffic to the same IP your inbound port forwards?
  15. ProudCanadian
    Aug 24, 2017
    47
    6
    As far as I am aware the most I can do with the firewall I have currently is specify the interface to send the traffic out on.
    But all this is for a workaround that I am really needing a proper fix for as I want the emails to come from our organisation.
