Conference in new client causes SSL error
Discussion in 'Windows' started by MichaelG, Nov 20, 2017.
  1. MichaelG
    Nov 19, 2017
    In 3CX 15.5 sp2 update the create and view conference buttons in the softphone client go to the webclient.
    The issue we are having is that it uses the <PBXLocalAddr> setting from the provisioning file, which in our case is a local IP address. This throws a SSL cert error because the CN doesn't match the certificate we have loaded. The FQDN under <PBXPublicAddr> points to the same IP in <PBXLocalAddr> internally anyway.
    Is there a way to update the <PBXLocalAddr> in the provisioning files?
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    258
    13
    Hello @MichaelG,
    Go to the extension that you want to modify and under Phone provisioning > Network click on the drop down list and change the Network interface for registration and provisioning to be the FQDN instead of the local IP. After that re-provision is require.
    This is happening because you do not have a Local FQDN. For more information follow this link.
    Thank you
  3. ryanfonash
    Aug 19, 2016
    5
    You can't create a local FQDN if you are using the .3cx.us hosted service though... So this still doesn't work.
    I'm using a 3cx subdomain so as to not have to worry about SSL certs - and this completely kills that.
  4. ryanfonash
    Aug 19, 2016
    5
    Furthermore, the user has to authenticate every time. There should be a token that gets passed from the desktop client to the web login so the user is logged in automatically.
