Conference PIN
Discussion in '3CX Phone System - General' started by rmayer, Jun 20, 2010.
  1. rmayer
    Jan 7, 2010
    58
    How does this new feature work? Doesn't seem to matter what I dial, as soon as I press # it ends the call... works fine if the PIN is turned off.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
  3. rmayer
    Jan 7, 2010
    58
    Perfect, thanks!
  4. compufirm
    Jan 4, 2010
    6
    The same thing happens to me, If I have conference pin turned on and hit #, It hangs up, If I shut conference pin off, it works great?
  5. rmayer
    Jan 7, 2010
    58
    Taken from the link above:
    "If the phone system requires a security PIN to create a call conference, you must enter it after the conference ID, separated by a *, for example: 100*0000 (where 100 is the conference ID and 0000 the system wide conference PIN)"
  6. nb
    nb Support Team
    Jun 7, 2007
    2,127
    152
    security enabled
    ENTER ID*PIN_SPECIFIED_In_CONFIGURATION
    Example if ID is 1 and pin is default 0000 and option is enabled you dial the following
    700
    Please enter conf id and then press point
    1*0000#
  7. compufirm
    Jan 4, 2010
    6
