NWTech said:Is is on Server 2008 Std 32 bit. Yes voicemail works when you dial 999.
Thank-you
SY said:NWTech said:Is is on Server 2008 Std 32 bit. Yes voicemail works when you dial 999.
Thank-you
After you enter the mail box there are few options. One of them is "press 9 for options". Do you hear menu description after pressing this button('9')? (it is like "press 3 to dial number, press 5 to change self identification message press 8 to change greeting promt" etc.)
NWTech said:SY said:NWTech said:Is is on Server 2008 Std 32 bit. Yes voicemail works when you dial 999.
Thank-you
When you dial the extension it is silent. If you select 9 nothing happens. In the logs I can see the call take place and a Call(98): device joined for the 700 ext and the ext starting the conference.
NWTech said:That is my I said "Yes voicemail works when you dial 999" I called 999 and enterend my ext and it told me I had no messages. Is that clear enough?
NWTech said:One of the guys indicated that there was additional setup for 2008 however he never shared it on this forum.
Thank-you
Hi, Mikeworksighted said:You cannot play back the mp3 files (which some prompts are mp3) until you have the codecs that windows media player intalls.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
