Solved Conference Rooms
Discussion in '3CX Phone System - General' started by AH2, Sep 5, 2017.
Tags:
  1. AH2
    AH2 New Member
    Mar 14, 2017
    112
    Hi there, Im having a problem doing conference calls using the 3cx app, for instance I go ahead and select crate new conference, set subject, then add the numbers I want to get joined, they are all external numbers ( 2 international 1 local ), the conference gets created fine, I get the waiting music, but the other 3 people invice fail, even if I try to re-dial and it fails again.
    [​IMG]
    Any idea ?
    Thanks,
    AH
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,425
    352
    Hello @AH2
    Please make sure you have an outbound rule that matches so that the PBX can call out to the participants. Do you get an error in the activity log of the PBX when this fails?
    AH2 likes this.
  3. AH2
    AH2 New Member
    Mar 14, 2017
    112
    I do have 3 outgoing rules that add a prefix 9957 to the outgoing calls, normal calls being dialed out of the 3cx client work fine, even to the same numbers trying to add in the conference, I just tried it again, added the number with and without the prefixes still fails when joining to the call, only the conference creator stays connected. No logs on events.
    [​IMG]
    The image represents every time I clicked redial to add the person to the conference but failed.
    Thanks.
  4. YiannisH_3CX
    May 10, 2016
    5,425
    352
    Can you please post a screenshot of the outbound rule the conference is supposed to match? Is the prefix the only requirement in the outbound rules?
    AH2 likes this.
  5. AH2
    AH2 New Member
    Mar 14, 2017
    112
    Those are the rules I have, yes the prefix 99 it's the only rule for outgoing calls, the 57 its to include it for Colombian calls.
    They are for all outgoing calls, I don't see any place to create specific rules for conference rooms.
    [​IMG]
    [​IMG]
    [​IMG]
  6. YiannisH_3CX
    May 10, 2016
    5,425
    352
    The conference room is a system extension that does not belong to any group. So if you specify a group in your outbound parameters the call will fail as the originator of the call is a system extension. With that in mind try creating an outbound rule specifically for the conference extension or remove that group from the outbound parameters. Please see an example of an outbound rule below
    AH2 likes this.
  7. AH2
    AH2 New Member
    Mar 14, 2017
    112
    Thanks a lot, that fixes the problem. :)
    Regards,
    AH
