Solved Conference Settings - Audio
Discussion in '3CX Phone System - General' started by Saqqara, Mar 8, 2018.
  1. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    Please can someone explain when the 'Require Conference Pin' is used
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    40
    Hello @Saqqara
    If you enable this option, then the organizer of the conference will need to set a conference pin so participants that want to join in the conference will need to enter this pin number as well in addition to the conference ID
  3. Saqqara
    Mar 12, 2014
    1,252
    203
    Thanks for the info
  4. mariosM_3CX
    Nov 1, 2017
    406
    40
    No problem, glad to help
