Conference to call forward
Discussion in '3CX Phone System - General' started by donbru01, Dec 16, 2014.
  1. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Hi at all , i have this issue on V12SP6 .
    My client is 2438 and when out of office call forward to Mobile Phone .All work fine !!
    Same if call incoming from IVR - call reroute to my Mobile Phone
    When i planning a conference call and extension 8890 call me at extension 2438 call dropped , for this reason get from logs "Forwarding disabled by nofwd=1 param"
    Have you ideas?
    Thanx
    SIP/2.0 480 Temporarily Unavailable
    Via: SIP/2.0/UDP 127.0.0.1:40300;branch=z9hG4bK-d8754z-5f17ca32292ac24b-1---d8754z-;rport=40300
    To: <sip:2438@127.0.0.1:5060;nofwd=1>;tag=e24ee47e
    Call-ID: OGRlN2IzNTAwZWUzMTc5OTgxMTZjMjMyZGZiMmNiY2Y.
    CSeq: 2 INVITE
    Warning: 499 3CXCITDC.AXITEASPA.LOCAL "Not available"
    Content-Length: 0
    16-dic-2014 14:29:02.824 SendMsg from <sip:2438@127.0.0.1:5060;nofwd=1>;tag=e24ee47e to "ff"<sip:8890@127.0.0.1:5060>;tag=4c586b3e
    16-dic-2014 14:29:02.811 ~Target=Ext:Ext.2438
    16-dic-2014 14:29:02.803 Call(C:2652) is terminated
    16-dic-2014 14:29:02.785 [CM503020]: Call(C:2652): Normal call termination. Call originator: Conf:8890. Reason: Not available
    16-dic-2014 14:29:02.785 [CM503016]: Call(C:2652): Attempt to reach <sip:2438@127.0.0.1:5060> from Conf:8890 has failed. Reason: No Answer
    16-dic-2014 14:29:02.785 Forwarding disabled by nofwd=1 param
    16-dic-2014 14:29:02.785 RerouteReq
    16-dic-2014 14:29:02.785 ~Route=Dev:sip:2438@10.10.1.1:2394;ob
    16-dic-2014 14:29:02.785 Reason: SIP ;cause=487 ;text="Request terminated, time out"
    16-dic-2014 14:29:01.833 L:2652.1[Conf] Sending: OnSendResp Send 180/INVITE from 0.0.0.0:0 tid=5f17ca32292ac24b Call-ID=OGRlN2IzNTAwZWUzMTc5OTgxMTZjMjMyZGZiMmNiY2Y.:
    SIP/2.0 180 Ringing
    Contact: <sip:2438@127.0.0.1:5060;nofwd=1>
    CSeq: 2 INVITE
    Content-Length: 0
    16-dic-2014 14:29:01.833 SendMsg from <sip:2438@127.0.0.1:5060;nofwd=1>;tag=e24ee47e to "ff"<sip:8890@127.0.0.1:5060>;tag=4c586b3e
    16-dic-2014 14:29:01.832 Provisional response arrived for session 1072881 of Leg L:2652.2[Extn]
    16-dic-2014 14:29:01.832 L:2652.2[Extn] got Provisional Recv 180/INVITE from 10.10.1.1:2394 tid=045a6c269b10510f Call-ID=NDBiMDc4MTc2MGMxYjk3ZWFhNTJjODk4NmQwYzdhZTA.:
    SIP/2.0 180 Ringing
    Via: SIP/2.0/UDP 10.10.4.203:5060;rport=5060;received=10.10.4.203;branch=z9hG4bK-d8754z-045a6c269b10510f-1---d8754z-
    Contact: "Bruno Donetti"<sip:2438@10.10.1.1:2394;ob>
    To: <sip:2438@10.10.4.203:5060>;tag=c519d9e9b88243c8b7d9d44187093cb6
    Call-ID: NDBiMDc4MTc2MGMxYjk3ZWFhNTJjODk4NmQwYzdhZTA.
    CSeq: 1 INVITE
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Can you detail further what is the call flow, and state what are the phone models used to establish this conference ?
    This log snippet is not enough to explain your issue.
  3. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Hi PJ3CX , i have make new test more simply ....
    ext.2438 ( 3CXPhoneWindows) when avalaible has call forward to ext 2001 after 5second toward Hardware phone 2001 ( GXP2100)
    than when another phone call 2438 call reroute correctly .
    When call incoming from Conference Server , call ring only to ext 2438 and not reroute to ext 2001 .
    Same case if 3CXPhoneWindows ext 2438 has call forward to my mobile phone .
    When call incoming from Conference Server , call not reroute to my mobile phone .
    Thanx
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Now I understand better your call flow, conference server will in fact not allow call forward from invited participants as a safety feature.
    You will have to invite 2001 directly to adress this issue.
  5. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Hi ,
    Thanx soo much .
    Good work
    Bruno
