conference
Discussion in '3CX Phone System - General' started by mayur123, Jan 25, 2013.
  1. mayur123
    Jan 25, 2013
    Is there somewhere to find the conference pin # other than the email invite?
  2. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    You already posted the same question, please avoid dups.
    As far as I know you can find the ADMIN pin, the one needed to create a conference, IF ENABLED, under the settings/conference tab. I am not aware of any place to find the actual conference PIN other than the invite email
