Conferencing requiring leader
Discussion in '3CX Phone System - General' started by Sean York, Nov 23, 2017.
  1. Sean York
    Mar 20, 2017
    6
    Is there a way to modify the dial-in conferencing so that it doesn't require a leader to be present before a user can dial-in join? If there is no way to do this.. this would be a fantastic feature!
    Sean Y.
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    38
    Hello @Sean York
    When you call the conference number it will ask you for the conference id. If there is such a conference id, you'll join that conference and if there isn't then a new conference will be created so others can join.
    If we assume that the first one to create a conference is the leader, then a conference with no leader is a new one, which you still can dial and create(and become the leader). If this is not what you mean, please describe in more detail what you are trying to achieve.
  3. Sean York
    Mar 20, 2017
    6
    I would like a user to be able to log into a conference ID where a leader is yet to be present. Some users tend to get to the conference before the leader has arrived. Other systems have something like a "participate code" when logging in.
