Config file could not be created...
Discussion in '3CX Phone System - General' started by Pentangle, Dec 14, 2007.
  1. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    When editing my general config on 3CX v5.0.3648.0 I get the following dialog box when I try and OK the changes:
    "Config file could not be created, possibly out of free disk space".
    I have 403Gb free :)
    Help?
    Cheers,
    Mike.
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Hi.
    Ran into the same after upgrade.
    Try to backup system, reinstall overwriting current install, then load backup.
    That worked for me, but i have read other posts stating a clean install is necessery.
  3. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Thanks - I backed up, uninstalled, rebooted, reinstalled, restored - and it worked.
    Then I had to find my license key...shame that's not kept in the backup!
    Thanks again,
    Mike.
  4. Mori
    Mori New Member
    Mar 23, 2007
    223
    I totally agree on the license issue.
    Specially for us that have several boxes for testing and trying.
    Estimated figures we have to install/reinstall 10 to 15 times a day..
    However i see the logic in those who have used a lisence, and dont want to renew it after it expires.
    A possible solution for this could be to let backup take the key, and make a "Unload Key" button in management console. (This probably should be in future request forum) :roll:
